in the middle of the shot cam jumped to time burst
Cüneyt Kaya
good old Berlin
www.allahead.de
in the middle of the shot, red cam jumped to time burst mode....the $$ $$$ usd shot is lost.
do others have experienced the same?
build 16 4k2:1 rc36
1st 2 shots had audio codec errors
then we shot without refernce sound (cam has new audioboard)
then when the shot started everything seemed to be fine.
after the post procedure was done on camera...the cam showed 1/48 shutter and time burst mode.
the shot was recorded in timeburst mode.
we enabled the suddenly activated time burst, than the same again....switching to time burst mode.-shot lost
edit: shot was recorded with two cams...so we only lost the closer one
which one?
I find it best to power devices from dtap.
Sounds like your menu is set to trigger the burst on that port, and thats exactly what you did. Check your menu settings for those ports.
good tip...thanks.solved
this is what i love about this community.
help in seconds
seems the audio codec error made some weirdos in the menus...
we didnt checked that
