jaadgy akanni
Does size matter? My wife wants FF35, I've always been happy with S35...
Only those who can't afford FF35 say size doesn't matter:rofl:
I'll buy all RED lenses. Does my opinion count? We are building the lenses I have always wanted. I'm not buying them because they are RED. I'm buying them because they are better.
Jim
Jim did turned the motion picture camera world up side down. But there are so many points that are not in favour of a FF35mm motion picture system which is not only used for the big digital screen but many other applications that investing in traditional S35mm glas remains meaningful, IMO.
Hans
There are many points to consider:
1. Pal/NTSC is around since 40 years or more. Most TV stations still broadcast SD. I bet 1080 will be around for the next 3 or 4 decades.
2. Less than 1/100 of higher budget projects will end up on the big screen. Not to mention all the music video, ads, coperate stuff, doccos, etc...
3. According to IBU modern 35mm projection is around 720p, maxing out at 800p. Most find the traditional screen already a challenge when ist comes to focus, VFX, etc....
4. Resolution is subjective. Why does a 35mm shot commercial look on televison so much crisper and prominent than on video shot news? Both have the same measured resolution.
5. Digital projection will be seen soon in many cinemas, no doubt. Is measured full 4K necessary? I doubt this. See point 3. and 4.
5. With S35mm I can control DOF nicely and find it very balanced between deep DOF and shallow DOF. With FF35 this will be more difficult.
6. FF35mm is an even bigger challenge focuswise. I find S35mm challenging enough. Devices such as electronic FF systems won't change the fact that the DOF is more shallow and hence more difficult to nail.
7. Speed. I don't know of any wideangle FF lens with a T Stop of 1.4.
8. Zooms. There are many who would love to see a S35mm zoom that maginfies 10 times but should not weight more than 2 kilogramm. Currently a S35mm 10-1 zoom weights 5+ kilogramm. Seems to be hard to pull off, if not impossible. FF35 will be even harder in this regard. Does anyone want a 10-1 which is even bigger than the Optimo 24-290?
Hans
But there are obviously some of us want to buy FF35 for whatever reasons. Everything you can do with S35 you can do with FF35 plus 6k plus DR.
Back to the topic lens buying plans. Why do they need the RED primes plus the upcoming FF35 electronic lenses?
The FF35 RED lenses will be a "different breed of cat" than the S35 RED Pro Primes... which are full manual "very cine" designs.
The FF35 lenses will have auto-focus, auto-iris and image stabilized capabilities (like current DSLR lenses) with "cine-accommodation" features... hence DSMC.
Jim
Autofocus, autoIris, and image stabilization...all proprietary capabilities, exclusively complementary with the camera brains?
Jim
Jim
So you can use the FF35 lenses on all models (except Fixed 8x obviously) and the only limitation is the sensor size. You can use, for example, an FF35 lens on an S35 brain and have full auto capability. There is a compromise doing this when shooting "cine" compared to RED Pro Primes. It will be better than shooting DSLR lenses from other manufacturers but not like using dedicated cine lenses. Again... DSMC.
Jim
I would also like to say the same way. However, better or best are not absolute issues but they depend on the needs of who rates lenses. My question is, will there be long RED teles and zooms having wide range available? Moreover, as I work with wildlife documents, also needed lenses which are not that heavy.
This lens issue is bit puzzling for won't be able to exploit the upgrade program to Epic X before there exists whole set of RED lenses or a working mount preferable to EF lenses.
So, could you Jim give us some idea what you think is the best way to go on, if one has this kind of special needs?
We just started this program and it will take us a couple more years to catch up on every possible option.
4. Resolution is subjective. Why does a 35mm shot commercial look on television so much crisper and prominent than on video shot news? Both have the same measured resolution.
