Zach Tucker
- Dec 30, 2008
- Age
- 51
I have a question from a practical visual effects/post production/delivery perspective. For over a decade I have worked on many obnoxiously big budget hollywood popcorn movies. About 98% of the footage I've put my digital hands on has originated from 35mm film. True film res is clearly higher than 2k but for 100% of those projects we scanned the film at 2k, did all our CG and compositing at 2k and delivered at 2k. I know there is justification for 3k, 4k, even 6k in a true "DSMC" rig, but how many companies have the infrastructure to work with 4k footage at any reasonable scale? The biggest VFX/post facilities I've been at have over 3,000 processors to render on, but jumping from 2k to 4k would QUADRUPLE render time. It would quadruple disk space, RAM and network traffic. And due to the need to have 12,000 processors in this case (to render the same number of shots at twice the resolution in the same amount of time) it would probably require 4x the AC to keep those machines cool. So 8x the electricity to cover the additional machines and AC? LA has already turned down vfx facilities requests for more electricity.
So who is actually shooting 4k, working at 4k and delivering at 4k? (vote in my poll if you'd like) Throw 3d/stereo into the mix (something that is clearly happening more in the real world than increased delivery resolutions) and you can double the above numbers. Until someone makes a 64-core machine with 128gb ram and uses 500w for $3k, there isn't a facility in the known universe that could handle such a 3d project.
I've also worked on some high-budget commercials shot on the Red One. Again, the Red footage is only ever used at 2k and delivered at HD. On set when a higher frame rate was needed the image was cropped, effecting lens choices. I understand the limitations of throughput and heat inside the units. I also understand scarlet/epic might shoot higher frame rates without a need for cropping. It's all a long-winded lead up to...
How many film/commercial productions need the "S" in "DSMC" (ie, 3k-6k)?
Is the proud new owner of a scarlet going to deliver his independent film to the festivals at 3k?
What if there were a brain/sensor option in the upcoming scarlet/epic to take advantage of the massive global industry who is working at (and limited to) 2k?
If that sensor were the same size (s35/red one) but was only a 2k chip (compared to 4k) wouldn't each pixel be 4x the size and thus gobble 4x more light?
Would your storage go 4x as far?
Would you get more latitude?
Would rolling shutter issues (which are a NIGHTMARE for vfx) be easier to eliminate due to fewer pixels on the chip?
Would your encoding go 4x faster?
Would you be able to shoot 4x the frame rate with the same horsepower and no need for a sensor crop?
It's kind of like having a Ferrari in LA. Sure, it *can* go 200 mph, but even when you're not crawling in traffic the cops are gunna nab you at 80 mph.
.z
.z
