I Bloom
Ian - obviously you are a more advance computer user. You probably have your system tuned in, do regular checks of your drives, etc. However, most people are not. Ive had a people call me out on my software telling me it was crap and that other methods were better - because my software was always failing their transfers. Then a week later they reply that their new harddrive failed or the card reader was not up to spec. Turns out that R3D Data Manager was identifying a problem that other software was missing or didnt check at all.
I wasn't making a criticism of R3D data manager, I was speaking of checksuming in general. I hear good things about your software and I know how hard you must have worked on it.
But on another level, you didn't write your own copy command did you (I hope not.) You are just calling a Unix command to make a copy. So is Finder when you drag and drop a group of files. So am I when I type cp -R into the terminal. We are all using the exact same code in fact. We'd be foolish not to.
Most software is also relying on the old unix infrastructure to calculate checksums. So in fact any criticism I make about this is really talking about the underlying technology. R3D Data manager, like Crimson, is mostly a front end.
In addition, most people on set simply dont have time to read the output of complex copy commands or check data sizes. After a 14 hour day, all I want to do is go home, thats for sure. So R3D Data Manager has a simple success/fail - and if you want more info, you can check the report. If you want even more info, you can see the activity log.
The end of a 14 hour day is when bad things happen to footage, whether we are clicking one button or a few.
But more importantly, R3D Data Manager removes a lot of area for human error. Select the root of the Red Media on set, and it will copy all the footage, every time. It will make sure everything was copied, and copied correctly. It will do 90% of the checks you should do as a DAS/DIT in an automated fashion, with one click. This way, you can click copy and do other more important tasks.
If you don't go yourself and look at the filesystem after you think you've made a transfer, you are in for real trouble. It doesn't matter what software you use or how tired you are.
Like I said I don't have an issue with R3D data manager, I think it's great and I've considered buying it. (Actually I have something we can barter maybe
My main issue is with the idea that not being directly involved in the transfer process and looking closely at the results is ever a good idea. In other words, it's not possible to write software to solve the main risks to footage on set since these are mainly human mistakes.
Checksuming while theoretically helpful, costs a lot of time, that in my experience can create more problems than it solves. Like I said, it's easy to prove me wrong, show me the files that passed my test and failed a checksum.
Ian
