Kyle Mallory
- Jan 18, 2007
- Age
- 54
- Salt Lake City
- www.ifastudios.com
If you have used (or attempted to use) an HDMI monitor with your RED ONE, please post (or PM me) your make, model, size, type, resolution, and firmware (if applicable), and whether the camera worked, or hung, and with which R1 Build(s).
It seems 95% of all issues result in the same outcome: Your R1 hangs. If this is what happens to you, just say so. No need for a long-winded description of what you tried and how you tried it. If you have partial success, such as support for "720p", but not "Menus", please note as such in your post.
I will attempt to keep this post up to date with the latest information.
If you are not sure what firmware you have on your TV, I'd suggest checking out the LCD Flat Panel AVS Forums. You can find guides and latest firmware info for most models. If you can't find your Firmware information, don't worry about it-- better to have make and model alone than nothing at all.
Note: It is my understanding that all HDMI->DVI solutions are known to work. As such, I do not intend to include these in the list (else this list be huge!). If you have a HDMI->DVI solution which does not work, please let me know, and I will include it in this list.
Make: Samsung
Model: LN-T4661F (Model Code: LNT4661FX/XAA)
Type: LCD TV
Native Resolution: 1920x1080
Firmware:
MODULE: T-TULPAUSC-1011, DATE:R1 Build(s): B15, B16, B17
MICOM: T-TULPAUSS-1011, ACL: T-TULPAUSG-1006
KERNEL:
Status: FAIL: Hangs/Crashes RED ONE
Reported By: Kyle Mallory
Make: LG
Model: LBD2DE
Size:
Type: LCD TV
Firmware: N/A
R1 Build(s): Unknown
Status: PASS: 720p, 1080p
Make: Panasonic
Model: TH-50PZ800U
Type: Plasma TV
Firmware: #0170-1110
R1 Build(s): Build 16 - 3.2.5
Reported By: Brent J. Craig
Make: Panasonic
Model: PT-AE2000
Type: LCD Projector
Firmware: N/A
Reported By: jdcineaste
Make: Panasonic
Model: TH42PZ800
Type: Plasma TV
Firmware: N/A
Reported By: Sam Roberts
Make: Panasonic
Model: PT-AE1000
Type: LCD Projector
Firmware: N/A
Reported By: Tim Blackmore
Make: Panasonic
Model: TC-32LZ800
Type: LCD TV
Firmware: N/A
Reported By: Brian Broz
Make: Philips
Model: 42PFL3603D/F7
Type: LCD TV
Firmware: N/A
R1 Build(s): B16
Reported By: Luis Ortiz
Notes: Reportedly worked on in-store model, but not in purchased model.
Make: BenQ
Model: FP241W
Type: LCD Monitor
Native Resolution: 1920x1200
Firmware: N/A
R1 Build(s): B16-B18
Status: PASS
Reported By: korgerb
Make: BenQ
Model: G2400W
Type: LCD Monitor
Firmware: N/A
Status: FAIL: Monitor does not recognize signal.
Notes: This monitor does not crash the R1 as others do, however the monitor does not support the video mode.
Make: LG
Model: 60PG70FD
Type: Plasma TV
Firmware: N/A
Reported By: jimhare
Make: Sharp Aquos
Model: 46D62U
Type: LCD Television
Firmware: N/A
R1 Build(s): B15-B18
Status: Pass: Only 720p reported.
Reported By: chosei
Make: Sharp Aquos
Model: 52D62U
Firmware: N/A
Reported By: chosei
