chris giuffre
Greetings fellow travelers...
the issue: while offloading footage from the red drives to computer I noticed the video track, as it were, was missing. Audio was there, and the file sizes indicated video content should be present, but no image.
Went back on set and found that on-camera playback was having same issue.
We have two cameras and were able to determine that it's not a drive problem, but more than likely a camera setting issue. Probably something really dumb, but for the life of me, I can't figure it out.
Went through all the menus and settings are seemingly identical on both cameras.
Just prior to this, our DP was asking me (I'm the Data Wrangler) about differences between Raw, RedSpace, and REC709. As we are both relatively new to this camera I went and did some research. He may have been messing with the menu settings at this point, but I see no reason why these settings should have any effect on monitiring or recording the actual image.
Strangely, when I do recording tests now, and exit on-camera playback the "no image" problem persists until I go into the Video > View sub menu and toggle the aforementioned Raw, RedSpace, REC709 setting back and forth to Raw.
Any ideas? while I wait for Red Tech to call back?
Any insight would be a great help.
Chris
Chris
