Tim Whitcomb
(1) first off - for windah's set up there are tonnes of solutions out there - see your favourite I.T. storage company for those. I cant help you with that.
(2) - FOR standalone MACOSX archive solution.
Heres is the simple solution that works for Ultrium LTO4 SAS tape drive that works with a MAC PRO using MAC OSX based (hosted) archive applications on OSX 10.5.6 an also work on the brand new MAC PRO 2009 2.93 OCTO (16 x Virt/core jobbie - thats this one I'm using right now). No need to sweat it .. this works and is used by most:
- ATTOTECH EXPRESSAS HBAs PCIE - R380 or the H380 (external SFF-8088 multi-lane SAS connectors
- HP desktop external Ultrium LTO4 tape drives either the Full Height HP1840 of their Half Height 1760
- TolisGroups BRU-PE (Producers Edition) - MACOSX BASED archive software
- some Ultrium LTO4 data tapes (HP or SONY are great)
- an SFF-8088-to-SFF-8088 multilane sas cable (maybe you can get one with the tape drive).
This absolutely works for archiving creative/post work.
Thats as simple as it gets and works 100%.
I have exactly this configuration and BOTH of these tape drives and they work fine on my old 2007 MAC PRO 8core and now n this new monster 2009 2.93Ghx 8 x core Nehalen with the R380 EXPRESSSAS in PCIE slot 2 (x16).
THere is a great deal of inforation on these threads> PLease revew and draw your conclusion. Simply the support of other component vendors for MACOSX is NOT THERE. (i.e Quantum and LSILOGIC).
Looking in these threads will get opinions on other solutions that work and the differences in teh tape drives and maybe the software.
Skip the rest if you like...
I also have a QUANTUM HH SAS LTO4 ULtrium tape drive. I'm ready to dump in the local landfill. I Had to buy an LSI SAS3442E-R PCI SAS HBA card (windows support only) to get it to work on OSX. (Stupid me!).. so dont go this route.
See these links. More if you search other forums.
http://www.reduser.net/forum/showthread.php?t=21284
http://www.reduser.net/forum/showthread.php?t=24522
http://www.reduser.net/forum/showthread.php?t=17496
http://www.reduser.net/forum/showthread.php?t=7556 (very long and detailed thread)
http://www.reduser.net/forum/showthread.php?t=23545
http://www.dvxuser.com/V6/showthread.php?t=155693
http://www.dvxuser.com/V6/showthread.php?t=114778
NO need to sweat. Maybe you can see this solution at NAB somewhere.
if you are a non OSX platform user then there a lots more options for windahs's and linux using tried and true I.T. backup solutions for tape drives..
If you are on a budget and dont trust your archives to cheap spinning disks or scatchable optical disks then you might want look at the line of HP DAT tape drives. These work with USB and SATA(??) not sure of the later.. and you can run on other machines that dont need an HBA.
THere are SCSI an Fibre Channel versions of the tape drives requiring difference (obviously) HBA's..
I mention the above configuration because it is cost effective and works wonderfully.
LAstly there are also CLIENT SERVER verison of TOLISGROUPS BRU and also other I.T. based and expensive archive and backup solutions that supports mostly all OS platforms.. plenty form which to pick and choose.
HTH
w
Thanks, this is fantastic... much appreciated!
