Kevin Wild
- Sep 13, 2007
- Raleigh, NC
- www.drawbridge.tv
Just regarding Red Alert, I've asked a couple times about this:
There are several ways to alter your image. I still do not know "best practice" for doing certain things. For instance, your image is a little on the dark side. Should you first raise exposure? Should you first go to the curves? Should you first go to brightness? Again, I know Graham or others know that one is more denigrating to the image, but I've never gotten the answer to this. I realize, by the way, different controls do different things. But there is overlap and I would guess that there is a "best workflow" way as in..."always best to start with XYZ and don't touch ABC..."
Just another example.
