Erik Widding
REDuser Sponsor
PLEASE USE THIS THREAD TO DISCUSS COMPATIBILITY ISSUES, LENS BEHAVIORS, AND ANY BUGS.
EF232LensLibrary19x is a must have upgrade for your lens mount, regardless of whether it is a new or old mount. This will fix all of the issues with the 85mm lenses (1.8 tripping camera power, 1.2 manual focus), and it does not break any of the other lenses. Some of the other 19_ releases took a couple of steps backwards...
UPGRADING
You will need to download the PC (beta) or MAC applications to upgrade the software, or use a terminal emulation program, and follow the instructions in the user manual (command sequence for upgrade is EX, SN, XM, BL).
Connect to the mount using a standard SPP profile over BlueTooth. The operating system will then present the lens mount as a standard COM port, which our PC or MAC applications, or any terminal emulation program,, i.e. HyperTerminal, can connect to. The lens mount will report over the airwaves as "BIRGER 01234" where 01234 is the serial number for the mount originally attached to that camera adapter, and "01234" is the passcode for the BlueTooth connection.
BUTTONS
There are three buttons {top, middle, bottom} and two button press durations {short, long}.
When a lens is first attached, a top-long and a middle-long button press are needed to get the calibrations to happen on both focus and iris.
*Quick focus calibration simply finds the stops on the lens, and returns to the current knob position. This allows for eliminating any drift that might occur over time with less than fantastic lenses. L-series (red stripe) don't ever seem to drift, and most gold-stripe lenses don't seem to drift either. But some of the sigmas and tokinas still do, and we are going to be working on that shortly.
DOWNLOADS
The manual:
http://www.birger.com/pdf/ef232_user_manual.pdf
The latest released library:
http://www.birger.com/drivers/EF232LensLibrary19x.bei
The PC application:
http://www.birger.com/drivers/BEI_Device_Interface_1.0_Win_XP,Vista,2000.zip
The MAC application
http://www.birger.com/drivers/BEI_Device_Interface_Mac_OS_X_1.0.0.dmg.zip
UPGRADING
BUTTONS
Top-Long: Move iris to wide open, initialize iris
Top-Short: Move iris incremental 1/4 stop open
Bottom-Short: Move iris incremental 1/4 stop closed
Bottom-Long: Move iris closed
Middle-Long: Do a complete focus calibration (5 to 11 seconds)
Middle-Short: Do a quick focus calibration* (1 to 2 seconds typical)
Top+Bottom: Initialize Iris
Top+Middle: toggle lens manual focus ring on/off (i.e. 85mm/1.2)
Bottom+Middle: "servo-safe-mode", eventually I will explain...
DOWNLOADS
The manual:
The PC application:
The MAC application
