- Thread starter
- #21
danbrazda
- Jan 29, 2008
- Age
- 66
- Richmond, VA
- www.vcutvhd.com
Hey Dan,
Glad to hear that you acquired a Red!
We're running a Multibridge Pro like Kaku and have used the Blackmagic output as the second display and it works fine, so perhaps you are correct in that Color and the HDMI signal from the Decklink are not talking. Did you also say that you were unable to get dual desktops using the other video card out?
Tim
The odd thing is I have no problems at all working with a dual display in Final Cut or anything else- both using the HDMI out of the Decklink HD Extreme and/or using the 2nd Graphic card output. It's only when I have to kill the extended desktop and go into Color and activate dual display that I lose my 2nd display completely. Logic says that the output preferences in Color are not set up right but I've tried all available flavors of Deckling HD outputs and nothing works.
Tim, what output on the Multibridge Pro are you using to feed your 2nd display? Are you working with Color in dual display mode?
