Redcine crashes after Crimson Intermediate Import
SirSpencer
Hi there,
my problem is that redcine crashes after crimson intermediate import. I exported an XML from fcp and used it with crimson for redcine. then I opened redcine and used the option "load all" to load all intermediates from the crimson directory. ok that worked fine. but then I wanted to load the redcine xml file and it didn´t work. problem is that I can´t select anything. the window with the different directorys opens but I can´t choose anything. just the button "close" works. after that I can´t close redcine with cmd+q. I have to use "exit redcine". ok thats not really bad but after I have closed redcine it crashes all the time. I have to delet the redcinefolder from libary. then it works again but just until I load the intermediates. then the game starts again.
what can I do? I need my project from final cut in redcine to work on it.
cheers,
ben
Hi Ian,
thanks for replay. That works better. But I still can´t open the xml file and I get the message "failed to load construct". I tried ur instructions from this thread:
http://reduser.net/forum/showthread.php?t=17798
But it didn´t work. Can u tell me how I can fix this problem?
Ben
