Dominic Jones
Hi Jonathan,Most of us shooting for theatrical release are going to be mastering to the DCI spec soon enough anyway and for all practical purposes and that's a 4k standard so while it'll be nice to have a 5k camera master I'm pretty happy working 4k and will be for the foreseeable future.
Whilst I essentially agree with all your points, I thought I'd add in a tuppenceworth of my own on the 5K front - the reason why 5K becomes a "magic" number for 4K delivery is that the bayer pattern approach yields just over 75% accuracy compared to full RGB approaches. Therefore, 5K acquisition is almost ideal for creating 4K deliverables, whereas as 4K acquisition falls a little short of the mark.
In actual fact, assuming a similar level of accuracy as the Red One (which is ~78%, iirc), you would want a minimum bayer resolution of about 5.1K to produce a "true" 4K image.
By the maths of it, assuming an S35 window size of 24x18mm, and that the FF35's active (6K) sensor area is true 135 size (36x24mm), the S35 resolution of the FF35 would be exactly 4K, so the question then becomes: Do you want oversampling to create a truly full-colour image, or are you willing to sacrifice a little colour accuracy for higher DR?
The noise issue will be interesting, as oversampling also reduces noise, so that battle can really only be fought once real-world tests can be done side-by-side. My guess would be that (unless there's a massive jump in performance as regards noise between the two) the differences will be negligible - but that's a total guess.
Of course, with most productions currently finishing at 2K (as in your experience), there's really no question that the FF35 would yield a better image.
Interesting times, and no doubt...
Dom.
