Installing Log & Transfer Plugin
Nathaniel Smith
New member
I'm having difficulty installing the Log & Transfer plugin for Final Cut. I'm running FCP 6.0.5 and the plugin simply doesn't show up in my import preferences in Log and Transfer. I've repaired permissions, restarted, and run the Final Cut Studio Installer many times and I still get nothing.
Any thoughts? Thanks
Hey Nathaniel,
I had a similar issue. Have you run the standalone QT codec installer (v3.5) since installing the FCP plugin? The FCP plugin comes with a newer version of the QT codec (v3.7) so if you have you'll need to reinstall the entire plugin again. Hope this helps.
Good luck.
