Jorge Díaz-Amador
- Apr 26, 2007
- Portland, ME
- www.cinematechnic.com
Now that I have sorted out my workshop configuration and tooling issues, I have begun making 80mm fronts for Zeiss Mk.I prime lenses (the 35mm T1.4's and the 16mm T1.3's).
Right now I am only making the Delrin ones, but I can make aluminum ones too. AL fronts need to be anodized (much longer turn-around), are costlier, and have to be bonded with epoxy to be secure.
My new Swiss lathe produces superb results. Very tight tolerances and smooth finishes. These 80mm fronts are dimensionally identical to the actual front rings on Zeiss Mk.II primes.
The great thing about these Delrin fonts is that they are very easy to install, so the lens does not need to be sent to me. Just heat the rings in a small oven and they slip right into place. Within minutes they cool down and shrink, gripping the front of the lens firmly and evenly.
PM me if you are interested in some of these. The ones I have made now are spoken for, but I will be ordering some more raw material to make a new batch.
I can make the bores in any diameter you need for other lenses, up to about 75mm. I use special Swiss 8-jaw chucks that have very light even gripping pressure, so I can make the rings concentric even when they need to be very thin (but about 2.5mm wall thickness is the practical minimum in Delrin)
