Adam Hebert
- Feb 27, 2009
- Age
- 40
I would like to apologize up front for what will undoubtedly end up being a long winded question. I am photographing a short film in April, on the Red One. We intend to frame for 2.4:1, and do not intend to finish on film. I will try my best to outline the steps I believe are necessary, and hopefully you all can correct the mistakes I undoubtedly make!
First off - our rental package includes a 320gb Red-Drive, a 16gb cf and 2 8gb cf's. These must be returned on the final shoot day.
Because the R1 cannot capture 4kHD or 4k16:9 on the 8gbcf at redcode 36, should we stick to the 16gbs and 320 gb? Is 36 necessary, rather than 28? Also, is it true that during camera moves, the 320 Red-Drive has tendency to drop frames?
Would it be better to capture at 4k 2:1, 16:9, or HD if we intend to down res to 2K? Keeping in mind that our final AR will be 2.4:1.
Could someone please explain the process of transferring the RAW data from the red-drive to an external drive? For instance, if we use the RED-DRIVE, can you simply copy the RAW to a Lacie external drive, via macbook pro? (We probably wont shoot more than 20 minutes of footage a day, over three days). Again, this may sound dumb, since I have limited knowledge of this subject, but can the RAW data be saved on a drive or a system, which DOES NOT have redcine or any of those programs, until it can be transferred to another system for the edit? Furthermore, if the CF cards are used, can those simply be copied onto a macbook pro in the same fashion?
Thanks in advance!
Thanks in advance!
