Attaching Base Production Pack
kylebainter
Chicago/SW Michigan
www.vimeo.com
This is pry a stupid question, but I'll ask anyhow. I just got my cam, and the base prod pack. I put the plate on the camera with the 4 lever nuts.... do i still need to use screws from the bottom onto the camera? If so, which ones?
One thing to be aware of - there's no need to massively overtighten the side hex bolts. I'd say a quarter turn past finger tight is enough. Any more can overstress the bottom plate or even slightly warp it.
If it ain't wobbling, or coming loose if you try wobbling the camera attached to a tripod, then it's tight enough!
