Well I guess the title says it all. I have to slash my budget in order to get funding and the film made. What is the the best output I can use. Digital preferably 2K. How would this effect workflow and output?
The theaters where I am (Caribbean) can do 2K but I am concerned about the quality of output from even a 4K master to a 2K out. I will shoot with the Red in 4K, the problem I have is how much will the efect the output?
But "2K projection" can mean different things in terms of the exact specs for delivery -- it may mean just Rec 709 HD broadcast projection or it may mean 2K DCI, so whether you finish to a 4K or 2K master, or a 1080P master, you'll need to then make a version for the projection system you will be showing it on.
You should shoot 4K RAW no matter what, the question is whether to finish to:
4K RGB
2K RGB
1080P 4:4:4
Any of those standards can be used for high-end cinema releases, whether through a film-out to 35mm or using digital projection. Any movie shot on the Panavision Genesis, for example, was recorded in 1080P 4:4:4 and then either finished as 1080P or converted to 2K RGB.
And the truth is that it can be hard to see a big quality difference from a 4K master to a 2K version. But if you can afford to finish to 4K RGB, then at least you've got the highest quality master possible from which you can make any number of smaller versions.
But as jpp said, most Hollywood movies are finished to 2K RGB, and almost all digital projection is 2K or smaller. Even the few 4K Sony projectors out there in theaters are showing 2K DCI files.
But "2K projection" can mean different things in terms of the exact specs for delivery -- it may mean just Rec 709 HD broadcast projection or it may mean 2K DCI, so whether you finish to a 4K or 2K master, or a 1080P master, you'll need to then make a version for the projection system you will be showing it on. And you'll need to make various masters for any home video deliverables.
The only problem with not doing a film-out is being limited to digital theaters, which may or may not be a problem. There are still more film theaters worldwide than digital theaters, and some places that say they project digitally are just showing you standard def video, like from a DVD, or broadcast-quality HDTV.
You finish to an edited & color-corrected digital master and from that, you make copies, downconversions, film-outs, whatever, but you always protect your master and vault it properly with back-ups.
My question is: What is your business plan?
Most indies that want to get to theaters make a film with the intent of entering it into film festivals to try to snag a distributor. In this case a festival is entered with a lesser format (DVD) and the film print or digital projection content only needs to be delivered if the film is accepted. If you get into a top tier festival it should be pretty easy to get an investor to put in the funds to make the print, or you can inquire about the availability of the digital projection equipment. Is there a local festival that aquisition execs attend?
If a smart distributor picks it up they will want to reprint it and maybe touch it up as well, so you want to preserve the pathway to a 4K proof.
Bob
