BoyChewingGum
New member
- Nov 2, 2008
Hi everyone
First time poster, long time lurker (and a very grateful one at that).
Not sure if I should have posted this in the Avid forum so apologies if that's the case.
I've just finished the offline on a short drama, shot @ 4k 16:9 on a Red One (build 16).
Edited on FCP with ProRes HQ files made by dropping the _M proxies into Compressor. I didn't have the storage for L&T 2k QTs nor found the speed of cutting with proxies directly satisfactory...
So now the producer's arranging the online/grade and it's looking likely we'll be posting at a facility house with Avid DS (or possibly Symphony Nitris). As such, I need to get the sequence from ProRes HQ 576x1024 to *something that Avid accepts* 1080x1920.
The sequence is only short (~7 1/5 mins) and consists of straight cuts and one dissolve.
So this is what I'm thinking for the conform:
1) Export an XML from FCP of the locked offline
2) Use Clipfinder to run a conform on the XML, rendering DNxHD QTs in the process.
3) In FCP, import the conformed XML from Clipfinder thereby creating a DNxHD sequence .
4) Export an EDL (3600CMX) from FCP from this new sequence.
Then taking EDL/DNxHD directory over to avid...
5) Import EDL
6) Batch import offline media - DNxHD QTs.
7) Finish the film!
Do people think this will work? This is my first RED project and I have to say, the difficulty with running conforms on sequences is a bit of a pain. Having to use Monkey/Crimson etc. etc. when the original R3D media is right in front of you and the offline files carry Reel # and TC is rather annoying to say the least.
As always I'm sure there are plenty of alternatives and I am all ears! Perhaps conforming via L&T to Redcode 2k QTs, rendering out a DNxHD or uncompressed 10 bit QT and importing EDL in Avid as cut list will work too?
Anyways, I'll be very grateful for all and any help offered.
PS I'm running late '08 MBP 2.8GHz, FCP 6.0.5, OS X 10.5.5, QT 7.5.5
5) Import EDL
7) Finish the film!
