FCP total clip runtime info?
Not sure if FCP has the solution, but you can always use your storage folder size and use Digital Heaven's footage calculator widget to do a reverse calculation.
I don't know of a specific function for that.
You could drop all your footage on a sequence, and look at the duration of the sequence...
That's exactly what I do- works like a charm.
Noah
Thanks for the replies. I did put all the footage into a sequence, but I had to use more than 1 because FCP apparently has a 12 hour sequence limit. The project is a feature film we shot with 42 hours of footage.
Chris
