Hello,
I'm testing out one of the workflows described in the RED FCS Whitepaper and running into a little trouble. I'm trying to use "Workflow 2: Work Offline Using ProRes; Finish Using RED QuickTime Media."
I used Log and Transfer to ingest the RED media into FCP as ProRes 422 QuickTimes. I've done this several times before, and, as usual, I had no problems. I cut together a short sequence and then MediaManaged it to create an offline version. So far, so good.
Then I switched the preferences in the Log and Transfer window to transcode to "Native." I select my new offline sequence and click Batch Capture, but I can't reingest the RED media. The Log and Tranfser window comes up and immediately gives me the error message:
Volumes Not Available:The selected clips cannot be imported because they originate from the following volumes that are currently not mounted.
I haven't moved or changed the RED files since my first Log and Transfer. Any ideas why FCP can't find them now?
