- Thread starter
- #21
David Morgan
Hi MichaelP,
Any chance when the Step by Step guide gets updated it will also include how to relink Audio(Timecode) that was recorded separately?
I asked the same question from my dealer and he pointed me to the Auto Sync feature in MC.
When you record footage that includes both audio and video, the system automatically establishes sync when it creates clips in the bin.Autosyncing applies to audio and video clips that have been recorded separately, usually from two separate sources. Autosyncing creates a new subclip that displays sync breaks in the Timeline as though the audio and video were recorded simultaneously.
Autosyncing is often used for film projects in which picture and sound are captured separately. These clips are often synced based on common film timecode or sound timecode. You can also autosync any audio and video clips based on an artificial IN point or OUT point relationship you establish with marks. Use the following guidelines when autosyncing:
· You can autosync audio clips with video clips only.
· You can create only one autosynced subclip at a time.
· You cannot autosync numerous pairs of audio and video clips simultaneously.
· If the audio and video clips do not have matching source, you must establish common sync frames.
To do this, mark IN points (or OUT points) on both clips before autosyncing. If you are autosyncing clips of different lengths, the longer clip is truncated to the length of the shorter clip. If you autosync according to common timecodes that are staggered (one clip starts later than the other), the later starting timecode becomes the start of the new subclip. The clip with the earlier starting timecode is trimmed accordingly.
Creating an Autosynced Subclip To create an autosynced subclip:
1. Highlight the two clips in the bin, and then choose AutoSync from the Bin menu. The Sync Selection dialog box appears.
1. Select an option, based on the following:
- Inpoints if you are syncing according to IN points set in both clips.
- Outpoints if you are syncing according to OUT points set in both clips.
- Source Timecode if the two clips have matching timecode.
2. Click OK. The subclip is created and named by default after the video clip with the extension .sync.n, where n is the incremental number of subclips created with the same name.
