Karl Kim
Up for sale are a set of 6 Lomo primes located here in the states. All in OCT19 mount- can be converted to PL overseas or domestically.
18mm T2.3 sn:87xxxx
22mm T2.6 sn:86xxxx
28mm T2.2 sn:91xxxx
35mm T2.2 sn:91xxxx
50mm T2.3 sn:90xxxx
75mm T2.2 sn:90xxxx
As you can see the 18, 22, and 28mm lenses have Arri pitch ff gears. These have all been used on features with excellent results. The 35mm is a new addition to this set. The 50 75 have been held in reserve, as I had a set of superspeeds. All lenses save the new 35mm have been serviced and are in excellent functional condition. The 35mm looks great, has a late serial number, and I fully expect it to be perfect for this set. Please note this is predominately a late model set.
Doug Underdahl at Long Valley Equipment makes an OCT19 mount for the Red, which we use often.
Also included is a 18mm with a damaged rear element. Someone dropped it.
Asking $2500.00 for the set, Paypal preferred. You can contact me direct at klkim at verizon dot net.
Thanks.
Karl
18mm T2.3 sn:87xxxx
22mm T2.6 sn:86xxxx
28mm T2.2 sn:91xxxx
35mm T2.2 sn:91xxxx
50mm T2.3 sn:90xxxx
75mm T2.2 sn:90xxxx
Thanks.
Karl
