Hi,
I'm working on a red project for the first time with my macbook pro, using OSX and Final Cut Studio 2.
When I try to open the red quicktime proxies in Quicktime or Final Cut Pro I can hear the audio but the image is simply black.
I have installed the REDCODE plugin. When I go into my Library/Quicktime folder I can see the REDCODE.QT.component.
Interestingly, I am able to import the quicktime proxies into After Effects CS3 and can view the footage there, however the right most quarter of the image is reduced in opacity, sort of like a white box set at 50% opacity is on top of the image, so I can't export a usable video image from After Effects.
I know the footage is fine because the director has viewed the footage on his mac and it all looks fine...I'm baffled!
A sort of related issue is that I have also installed the "RED Final Cut Studio 2 Installer" but when I go into the "preferences" menu in the log and transfer tool there is no "RED digital cinema REDCODE" option as indicated in the "Red FCS studio whitepaper". So I can't even export ProRes 422 versions of the movies to work with while I try to sort out this other problem.
Any help with these issues would be greatly appreciated since I'm on a deadline with this project.
Thanks so much.
Thanks so much.
