Roberto B
- Dec 31, 2006
nice to knowMy audio board upgrade came back yesterday and the new mic pres sound GREAT! Very clean. No noise.
I'm with all everyone on going out and feeding a proper signal, but all I'm trying to say is that when miking I find its more about the space than the mic used, etc.
I am easily satisfied, this is true, i don't mind glitches and the such, of course if avoided would be ideal, but in this case, set up an entire multitrack facility on set, then have your condensers charged up and ready.
I just like the SM58, if I'm plugging into a camera, that's probably what I'd do.
I do like to fix in post, I think certain things can be made up for.
At the same time, I've been in audio at a studio recording music for a while, I just started with imagery and booming is completely different for me than the ultra controlled environment you can build in a booth.
I dunno if I'm clear, I have been a mess so I may skip words, but I think if the red has outputs, or if you're recording into something where you can see a lot more than a VU meter, it would be a different case.
Sorry guys, thought I was helping.
Not feelin well. I'll keep it to myself next time, thought someone wanted to plug straight in and go. Fixing it in post is just how i play safe.
Cheers REDusers
Tarek
Sanjin, if red one's fan is giving you an issue then you should look into a shotgun with a narrower pick up... and a skilled boom op that can handle it properly cause the narrower you get the exponentially trickier it gets to mic properly. If you weren't using a directional mic then any shotgun might do the trick so long as you mic away from the R1 and not towards it.
Rub it in. Unfortunately, I am going to possibly be the very last person to get the audio board upgrade since my camera delivered August 31, two weeks before they made the switchover in delivering the cameras with the new board. I'm wondering if Epic will be here before my sound board upgrade. It could happen...
USlatin,
imagine you are shooting in a car at the temperature +30C/95F with R1 that has a boom/consender mic on.
Only noise of car engine and loudness from outer traffic jam can save you from hearing R1 fans.
I do not have still problem with R1 fans (now is winter in Austria) but just thinking about a hot summer shooting with boom mic on the cam.
-Tarek
A microphone is like a filter or lens on the camera. It allows you to capture different patterns of sound. Just like a camera filter, you'd use a microphone that helps your specific setting.
My motto is this: no matter how low budget you get, always make sure you get good audio. Hire a good sound recordist to grab your audio. Bad audio makes for a bad headache down the road, and a dent in your wallet.
-Brian
