Debayer Quality for FCP Log & Transfer?
Does FCP always use Half Res Standard? Is there a way to control this? This is for both transcoding to ProRes and rewrapping to QT.
Ernesto
The control panel installed with the codec should allow to set half-standard or half-high.
By going into control panel then select half-high. If you don't see it, then you have to install the RED REDCODE 3.5.
Note that the control panel is not packaged with the
"Final Cut Studio 2 Installer". You have to get it via the
"Red Quicktime Codec (Beta)" download.
