Scarlet Stereoscopic Newbie
52
Munich
www.25frames.de
Hello,
first: sorry about my bad english.
At this time im working with 2 Canon XHA1 and a beamsplitter to produce stereoscopic footage.
So i´m very interested for the scarlet and the 3D-RIG.
But my question is if anybody knows if i´m needing optional hardware for stereoscopic productions with the scarlet?
How i can sync both cams? The 3D-rendering (360° turnaround quicktime) i´ve seen in internet shows me only two scarlets with a REDmote and the REDhandle.
Is that right that i need only these two items together with 2 scarlets for building a basic stereosystem? (without a preview monitor or 2 EFV)?
And anybody knows the prices for REDmote and REDhandle?
Thanks for help.
Martin
Prices are not known till now.
As far as I know you need two Scarlet, a 3D Baseplate (to arrange the angles of the Cams) and maybe two Bomb Viewfinder. You need the last ones to check the 3d of your Footage.
As the Scarlets are able to communicate I hope Red will provide a Firmwaresetting to Sync two Scarlets (would also be good in multi-angle-shots)
George
And now in German
Preise sind, bis auf die Brains, nicht bekannt.
Soweit ich weiß brauchst du zwei Scarlets, eine 3D Basisplatte (für den Kamerawinkel) und vielleicht noch zwei Bomb Viewfinder. Die brauchst du um zu checken ob dein 3d gut eingestellt ist.
Da die Scarlets miteinander komunizieren können sollte es per Firmware eine Möglichkeit geben die beiden Kameras zu syncronisieren.
Wenn du mehr Infos brauchst und dir das Englisch hier zu anstrengend ist kannst du mich gerne per Mail weiter ausfragen. Ich werde mir nämlich auch ein 3D Kit zulegen.
George
Hi
the oldest trick can sync 2 cameras, use a SLATE!
it can also use a flash a extra assurance.
it comes to a technical issue, as 2 cameras might have slight differences say - 24 FPS at both cameras and u probably have max. half frame difference, say camera A runs first, and camera B runs later but the frame somehow will be maximum 1/2 frame differences. if u use a slower shutter speed should not be a problem.
rest is labelling, as u must separate the files to LEFT/RIGHT
it's logistic nitemare.
have fun
K.M.Lo
