I read somewhere that CS4 now support XML?? If that is the case, you can try export the timeline as XML, try to read it in Color, if that doesn't work, import it in FCP and send to Color? Worth trying I guess.
I don't yet have CS4, but it is my understanding that you can export the Premiere project to a FCP compatible file. That should allow you to open it in FCP and Color.
