MIKE TESTIN
- Apr 6, 2007
Has anyone tried this trick. Is it safe for the sensor?
This may apply. I've worked in digital capture for the past eight years for still, and removing a lens to clean the sensor is a tricky thing. You are likely to get more dirt/dust that you originally had. Here is a trick I used. I would find a bath room, hopefully one with a shower, and turn on the showers COLD water, and let run for a few minutes. This will help remove some of the airbourne dust. Make sure power is off, as a powered up sensor will attract dust like a magnet. Then I used Sensor Swabs, made especially for digital sensor and Eclipse cleaning solution. Wet the swab, but not dripping wet, wipe swap across sensor in on direction, then turn sensor over to unused side, and wipe in opposite direction. If you need more cleaning, DO NOT USED SAME SWAB GET A NEW ONE. I'm told the the sensor is the same in the Canon 5D digital camera. You can buy swabs to match that sensor size, they are a bit pricey.
http://www.pictureline.com/products/14255/Digital_Survival_Sensor_Swab_Kit_Type_2_-_Eclipse/
If you are just changing lenses, power down and find the least dusty place and swap lenses quickly. Should you get dust, see above.
I want to see it too
would love to see how Lynch removes the lens from the PD150 while shooting)
If this works for you, fine, but I much prefer electrostatic cleaning which leaves no residue.
Rather than wet swabs, a Arctic Butterfly is much, much safer and 100% effective. It's a snap to use and takes only a few seconds.
Good shooting and best regards,
Leo
If anyone desires our PD-100 for some lynchian cinematography, I'm prepared to trade it for a Scarlet fixed lens (or a R1 if you insist on speedy transfer).Haha! well the "lens whacking" was in his pre-PD150 days. :bleh:
What effect does this achieve?
Removing the lens during a shoot can provide a number of effects depending on how you choose to do it.
By removing the lens and holding it (a lightweight lens!) a short distance in front of the mount you can get a defocus effect that can be similar to a macro shot along with being able to alter the focus plane like a tilt/shift lens. Being hand-held often introduces a very "organic" shake into these effects that can really give a feel/look that can I can only describe as "Lynchian"! (Adjective error... My words have failed me!)
Used appropriately it can be a real mood enhancer!
On top of the above effects light can leak from the gap between the lens and the mount onto the film plane. This light is from outside of the light cone from the lens and can provide some amazingly odd flare effects.
It is a purely creative in-camera effect and will probably take many attempts/takes to get what the shoot needs.
But use this technique with extreme care as damage can occur to both camera and lens if one is not careful.
JohnF
