Sean Rawls
- Apr 24, 2007
- Portland, OR
- www.seanrawls.com
First off, I can't express the deep sense of satisfaction (and maybe arousal) I get using R3D's with the Red tab in Color. This rocks. However, after running some tests I have some questions:
1) When I render a "native" QT wrapped R3D with the sequence codec set to "REDCODE" the entire clip goes gray. Is FCP just not designed to do this? Is native editing possible Do I have to render in another codec (prores) if I want to see reasonable playback?
2) I'm using a Mac Pro 8-Core and even though everything else is working fine, the RedCode icon doesn't appear in the system preference window. Anyone else experience this? I'd really like to change my debayer quality. (already tried reinstalling the Red FCP Plugin)
3) I've been working up a table with transcode times for clients and had an interesting result that I wanted to bounce off someone else:
-Transcoding 10 seconds of Redcode36 4K 2:1 24fps to ProresHQ took 34 seconds and resulted in a QT file with a data rate of 202 mbits/s
-Transcoding 10 seconds of Redcode36 2K 2:1 120fps to ProresHQ took 60 seconds and resulted in a QT file with a data rate of 235 mbits/s
Is the discrepancy in transcode time just because of the frame rate difference (24 v 120)? I guess I thought the resize from 4k to 2k would slow things down more. Also, why would the 2k originated prores file have a higher data rate (202 v 235)?
I realize this is a lot of stuff to digest . . . but I would really appreciate any help/advice/ramblings on any of these questions.
