Joe G.
"So the Red One using Redcode 36 records 4k at a rate of 36 mbps[SIC, MB/s] and the 5D records 1080P at a rate of 38.5 mbps. "
Divide by 8.
38.5/8 = 4.8 MB/s.
Divide by 8.
38.5/8 = 4.8 MB/s.
This whole thread is trash Canon never aimed this camera at the same market as Red stating at its Photokina launch that it was aimed at wedding photographers (unless wedding photographers have bought Red!)
Its like comparing a flat panel TV to a photoframe get real and talk about serious cinematography issues.
holy cow.. are you sure you bought the same camera model as me?..![]()
Actually, I'd like to add one more situation where a 5Dii would make sense. In the 12/08 issue of Videography magazine, Danny Boyle was interviewed (you know, Slumdog?), and says in the article, "We also used a Canon stills camera, which takes 12 frames a second. If people see a still camera, they don't think it is recording live action... Anthony would look like a tourist from Denmark who was wandering around the slums, but actually what he was doing was filming."Where the 5Dii fits is for "doing serious photography" - as in "wow, what a beautiful sunset", "so this is Antelope Canyon", "babe, don't move, the light is perfect on your back".
Here's the Canon EOS 5D MK2 audio sync issue or problem.
Last Wednesday I used my two 5D MkII's in a 3 camera music video shoot. The third camera was a Sony PMW-EX1. Audio was recorded on two additional devices. One audio recording device was an Edirol R4 Pro. The other audio recording setup was a Tascam USB Interface to a MacBook Pro.
The Sony Camera, Edirol, and Tascam/MacBook Pro devices all synced sound perfectly over the full duration of the shoot (just over 20 minutes). To clarify - once the different sources are sync'd quickly and easily to the slate clap on the waveform at the beginning of the shoot they all stayed perfectly in sync for the rest of the video.
Both Canon cameras audio and video sync'd perfectly to each other but drifted significantly from the other 3 devices even over a 3 minute segment. That is a very serious problem for me and one that introduces significant post-production trouble and expense.
This issue was so unexpected (I haven't run into this in years of working with a range of equipment) that I performed 3 subsequent tests to confirm that the 5D MkII's run too fast. The results from the tests show both of my 5D Mark II's run about 14 frames too fast in 10 minutes. Audio that is 1 full frame out of sync is noticeable on sharp sounds causing an echo. Audio that is 2 or 3 frames out of sync causes echo on any sound and looks odd in terms of lip sync.
That the two Canon cameras audio sync'd OK to each other tells me that the cameras can be calibrated to a standard. Evidently they are just calibrated to an incorrect standard.
Anybody else experience this? Does anybody really know if this is likely a chip issue or a firmware issue? Does anyone know an easy, reliable way to get the clips to conform to the standard without time-consuming constant tweaking?
I contacted Canon tech support and the girl there wasn't too concerned. She said: There is no fix and that the 5d isn't really a video camera so what did I expect? Nice!
It seems like it's because the 5D mk2 runs at 30 fps instead of the 29.97 fps that the broadcast cameras are running at. Are you using FCP? Try using Cinema Tools to 'Conform' the 5D footage to 29.97 from 30. That might fix the drift.
