I have a PANASONIC BT-LH1700WP monitor and I don´t know what´s the best setting to monitor when shooting 24p. Does anybody have this monitor ?It displays at 1080/60i. Apparently, I can not swith to a progressive display, unless you use a GPI-D-SUB, 9 pins or RS-232C: D-SUB, 9 pins remote unit for external control. I don´t know what the hell is that, and the manual is useless. Anyhow, I´m a bit confused here. If you shoot 24p, should you monitor the signal in progressive mode too ?....What does it do to the input signal if the diaplay mode is interlaced ?...what difference does it do the frequency or refresh rate ?....
how sould you set your monitor in relation to the camera settings, concerning frame rate, refresh rate, shutter speed, monitor frequency ?
What´s the relation between recording frame rate, display frame rate and refresh rate ?...how do the conversions between them work ?
What settigns should you set in your MAC en every case ?...Do you hace to change your settings everytime according to your shooting parameters, or there is a standard set of values for setting your monitor and MAC to work properly ?
I´ve read a lot of this stuff but it´s a bit overwhelming !
