D. A. Metrov
- Dec 1, 2008
Hi,
I'm working with 4k files in Premiere Pro. I have some shots done with green screen. The chroma key in PrePro doesn't seem to work nearly as well as KeyLight in AE. I've removed the green screen bg in AE, but am having no success getting it back into PrePro. I've imported the PrePro sequence into AE, then removed the green background. But the change IS NOT reflected in PrePro as promised. If I import the new AE compostion into PrePro, then PrePro says it can't find the original source material. Neither way seems to work.
Is anyone else having any luck using Adobe Dynamic Link?
Is there something I might be doing wrong? All the tutorial movies I've watched say that any changes in AE should be instantly reflected in PrePro.
Also, I can't "import" R3D files directly into AE. AE says the file type is not supported [even thought the RED plugin is installed, and shows up under "Edit/RED settings."]
Any thoughts/help much appreciated. Thanks
