LCamak
I know the guy who can advise you. Bob has done this with many launches from bunkers using both HD and film cameras. PM me and I'll get you in touch with him.
FWIW, I seem to remember he used a timer to turn ON and off the camera at the appropriate intervals (the windows that are open for launch if the first one is scrubbed). Problem is I don't know how to turn ON the RED without pushing the button, but I'm sure someone can figure that out.
NASA has restrictions with cell phones and wireless.
For the record function he used a small and cheap shock detector hooked to a GPIO. As close as the camera is, the Atlas will start pounding the ground almost before any gas is visible. I saw his footage, it missed nothing of the launch that was visible from the bunker.
Use the Cards, hard drive will probably drop frames on the shock waves (like just discussed regarding use of blanks). Wait til you feel it from 3 miles away. Not enough there to drop frames, but very noticeable.
He was allowed to set up only 24 hrs before launch. Anyways, this guy is wonderful to give you all the info. There is much more to consider regarding salt water air, condensation on the lens, camera support and the shock waves. Most importantly Bob has unbelieveable connections (Bob co-founded the Apollo I memorial and annual memorial services there for Grissom, Chaffe and White).
I let him use my Kinor 35mm camera once. With what the camera went through just in being next to the ocean for over a day(might have been 2 days as they don't exactly let you run out as soon as its launched), I declined further launches.
All the best,
lael
All the best,
lael
