Anyone use a Cinesaddle with a RED ONE?
Brandon Fraley
41
Bay Area, Ca.
i dunno, it looks really cool for small cameras, but does it work as well with a 30 pound RED?
THANKS! :)
30 pounds are not an issue. It is very convenient but not for a long time because the airflow might be reduced when the camera is "seated" on the saddle.
forgive me, but I don't understand what you mean. :(
They rock! I have had one for about 6 years and use it on every shoot. The big one can handle a red no prob. A must have.
As you know the camera has vents on the bottom just above the base on the sides in an angle. When placed on the cinesadle as any heavy object would on a pillow the sides of the cinesadle around the camera are forced up and normally cover the side vents. There for air flow will be limited when the camera is on resulting in fast over heating. Very often on shoots we make sure to limit the amount of time the camera is placed on (or in) a cinesadle for this reason. If the location is indoors and the takes are going to be long then we would make sure there are ice packs standing by to wack on between takes.
Ah, camera's fans, got it.
So you guys recommend the cinesaddle with large cameras?
I am sorry to be cryptic !
When you install the camera the camera on the saddle, it does not remain on top but rather confortably "make its nest" inside the saddle.
Let's say you put your fist on a pillow and press heavily downward, some part of your fist have no contact with air because you are partly wrapped into it !
There is a need to let hot air pass through on the lower part of the RED.
When the camera is in contact with the saddle, less air can go through,
the RED might heat more because less air is expelled, the saddle can block the aeration vents.
This issue can be solved by using RED side handles but then the bulk of the camera does not fit to my taste for hanheld use. I rather keep it small.
So, I do not use the side handles but I do not leave the RED "ON" more than than needed to film a shot and take it off the saddle.
Hope I was more clear.
Good work!
I've used a Cine Saddle frequently for several years now. For use with my RED cameras I own two versions: Marsupial Cine Saddle (for larger camera setups), and Marsupial Mini Saddle (for smaller camera setups). The "Marsupial" designation is simply for the versions that have an inner pouch to store accessories.
I love my Cine Saddles! They are way useful for getting certain types of shots - ground level, mounted on objects, etc.
The advice about not covering for any length of time the air vents on the bottom sides of RED is very good advice. One workaround has been mentioned - use the side handles, or something else to prop the bag outward and clear the airflow to the camera vents. As mentioned, for short, quick shots that shouldn't be an issue.
Here's a link to the Cinekinetic web site:
http://www.cinekinetic.com/new/index.html
Note: I also use the Pocket Dolly from Cinekinetic, which you'll see on their web site. Their products are very cool - and in creative hands they enable cost effective shooting of some really unique shot sequences.
If you don't want to ship from Australia then you can buy them in the US from Abel. The CineSaddle is one of those rare items that no one on REDuser should find the need to gripe about the price. Very inexpensive and functional.
I have a large Cinesaddle, and it friggin rules.. I've used it for low shots, car mount, and even a way to protect the camera while waiting for it to go on sticks.
Seriously I cannot say enough good about this. It's also important to note that this thing is built like a TANK. Very tough, so don't think a simple bean bag will do the trick.
Get one, no matter the camera, you will love it
Jay
K, I think I'm gunna do it (maybe not immediately, but it's next on the list)
Do I have to get the big boy, or will the minisaddle work with a modestly loaded RED? One thing i'm hoping to do is use this for wheelchair work, so the saddle would be sitting on my lap, and the big cinesaddle looks like it would be difficult to do that with.
The bigger one is more efficient against vibrations but takes more space, it all depends what primary use you have !
I have a large one that I keep in the car all the time, very useful.
Aloha
-A
Also, the Cinesaddle is great as a place to rest the camera when you're shooting handheld. I keep one around for a great place for the AC to set the camera with handles on it.
last question: original or marsupial?
I bought a marsupial cinesaddle (the big one) a few months ago, and I have to admit, it's just awesome.
I can think of so many situations where this would have been useful in the past... The only thing I regret is not buying one earlier...:)
