REDCINE Crashes - Part 1
Jesse Johnson
:help:
This is too long so I'm going to have to split it between a couple of posts. Okay, I've created a sequence in FCP that's 29 shots long, using the M Proxies. I've double checked my steps in Crimson and in REDCINE and when I try to load the intermediates into REDCINE it crashes. This happens EVERY time! It might be a problem with FCP, I don't know. Below is the rather long but probably important error report generated by the system. I'm going to send this off to RED too but hopefully someone on the boards can help too.
I'm running a Mac Pro 2.8GHz Quad-Core Intel Xeon with 6GB RAM, nVidia Geforce 8800GT Graphics. And yes, I've already tried uninstalling and reinstalling REDCINE and it does the same thing. :turned:
Also, when I try to load the shots one by one instead of using the "load all" option, it loads some .R3D's, but when I try to load certain individual .R3D files, REDCINE crashes. I have three back-ups of my footage, I may try later tonight to replace all the files on the hard drive I'm using. Maybe there's a corrupt .R3D file.
I would appreciate any help anyone could offer. Thank you.
PROBLEM DETAILS:
Process: RedCine [217]
Path: /Applications/RedCine.app/Contents/MacOS/RedCine
Identifier: RED.DIGITAL.CINEMA
Version: ??? (1.22)
Code Type: X86 (Native)
Parent Process: launchd [66]
Date/Time: 2009-01-03 17:36:10.165 -0600
OS Version: Mac OS X 10.5.5 (9F33)
Report Version: 6
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 20
Thread 0:
0 libSystem.B.dylib 0x927124a6 mach_msg_trap + 10
1 libSystem.B.dylib 0x92719c9c mach_msg + 72
2 com.apple.CoreFoundation 0x960690ce CFRunLoopRunSpecific + 1790
3 com.apple.CoreFoundation 0x96069cf8 CFRunLoopRunInMode + 88
4 com.apple.HIToolbox 0x931e3480 RunCurrentEventLoopInMode + 283
5 com.apple.HIToolbox 0x931e3299 ReceiveNextEventCommon + 374
6 com.apple.HIToolbox 0x9332654b ReceiveNextEvent + 58
7 AssimServices.dylib 0x2df31bc8 win_base::wait(double) + 120
8 AssimServices.dylib 0x2dcc81a6 asrv_process() + 266
9 AssimComponents.dylib 0x44bbebed Exec_REDCINE + 883
10 RED.DIGITAL.CINEMA 0x00002ce4 0x1000 + 7396
11 RED.DIGITAL.CINEMA 0x000022c2 0x1000 + 4802
12 RED.DIGITAL.CINEMA 0x000021e9 0x1000 + 4585
Thread 1:
0 libSystem.B.dylib 0x927124ee semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x92744866 _pthread_cond_wait + 1267
2 libSystem.B.dylib 0x9278a371 pthread_cond_wait + 48
3 AssimCore.dylib 0x0003159d m_entry(void*) + 87
4 libSystem.B.dylib 0x927436f5 _pthread_start + 321
5 libSystem.B.dylib 0x927435b2 thread_start + 34
Thread 2:
Thread 3:
Thread 4:
0 libSystem.B.dylib 0x9271968e __semwait_signal + 10
1 libSystem.B.dylib 0x9274436d pthread_cond_wait$UNIX2003 + 73
2 libGLProgrammability.dylib 0x909a1b32 glvmDoWork + 162
3 libSystem.B.dylib 0x927436f5 _pthread_start + 321
4 libSystem.B.dylib 0x927435b2 thread_start + 34
Thread 5:
4 com.apple.audio.CoreAudio 0x9091a468 HALRunLoop::OwnThread(void*) + 160
5 com.apple.audio.CoreAudio 0x9091a304 CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x927436f5 _pthread_start + 321
7 libSystem.B.dylib 0x927435b2 thread_start + 34
Thread 6:
0 REDCODE.node 0x4a3aafaf kdu_thread_env::kdu_thread_env() + 239
1 REDCODE.node 0x4a4a6bb2 kdu_thread_env::new_instance() + 30
2 REDCODE.node 0x4a440651 kdu_thread_entity::add_thread(int) + 177
3 REDCODE.node 0x4a474ab6 REDCORE::WaveletDecoder::WaveletDecoder() + 414
4 REDCODE.node 0x4a37a6c6 REDCORE::RedClip::DecodeVideoFrame(unsigned long, OutputJob&) + 760
5 REDCODE.node 0x4a49f2d4 RC_Track::decode_image(int, int, int&, double&) + 462
6 REDCODE.node 0x4a49fa66 RC_Track::ensure_image(int, bool) + 306
7 REDCODE.node 0x4a49fbb0 RC_Track::prefetch_image(int) + 68
8 AssimServices.dylib 0x2dca2c29 cache_thread_entry(void*) + 441
9 AssimCore.dylib 0x00034a48 as_thread_entry(void*) + 26
10 libSystem.B.dylib 0x927436f5 _pthread_start + 321
11 libSystem.B.dylib 0x927435b2 thread_start + 34
Thread 7:
0 libSystem.B.dylib 0x9271258a swtch_pri + 10
1 libSystem.B.dylib 0x92780bc1 sched_yield + 18
2 AssimCore.dylib 0x00034533 mp_yield() + 11
3 AssimCore.dylib 0x0002c565 io_complete64(int, int*, bool) + 119
4 AssimCore.dylib 0x0002c87c io_read64(int, void*, long long, unsigned long) + 78
5 REDCODE.node 0x4a3791a3 REDCORE::File::ReadFromFile(REDCORE::Buffer&, unsigned long) const + 995
6 REDCODE.node 0x4a3782e6 REDCORE::TokenStream::GetBytes(REDCORE::Buffer&, unsigned long) + 172
7 REDCODE.node 0x4a37830d REDCORE::TokenStream::GetBytes(REDCORE::Buffer&) + 37
8 REDCODE.node 0x4a3778ac REDCORE::Tokenizer::GetPayloadInNewBufferFromOffset(unsigned long, unsigned long, unsigned long, char const*) + 122
9 REDCODE.node 0x4a375c6a REDCORE::RedFileParser::ParseFrameFromFile(unsigned long, REDCORE::MetadataStore*) + 118
10 REDCODE.node 0x4a37a580 REDCORE::RedClip::DecodeVideoFrame(unsigned long, OutputJob&) + 434
11 REDCODE.node 0x4a49f2d4 RC_Track::decode_image(int, int, int&, double&) + 462
12 REDCODE.node 0x4a49fa66 RC_Track::ensure_image(int, bool) + 306
13 REDCODE.node 0x4a49fbb0 RC_Track::prefetch_image(int) + 68
14 AssimServices.dylib 0x2dca2c29 cache_thread_entry(void*) + 441
15 AssimCore.dylib 0x00034a48 as_thread_entry(void*) + 26
16 libSystem.B.dylib 0x927436f5 _pthread_start + 321
17 libSystem.B.dylib 0x927435b2 thread_start + 34
Thread 8:
1 libSystem.B.dylib 0x92719fc5 pthread_mutex_lock + 569
2 AssimCore.dylib 0x00034622 mp_get_mutex(__mutex_str*) + 24
3 REDCODE.node 0x4a37a41c REDCORE::RedClip::DecodeVideoFrame(unsigned long, OutputJob&) + 78
4 REDCODE.node 0x4a49f2d4 RC_Track::decode_image(int, int, int&, double&) + 462
5 REDCODE.node 0x4a49fa66 RC_Track::ensure_image(int, bool) + 306
6 REDCODE.node 0x4a49fbb0 RC_Track::prefetch_image(int) + 68
7 AssimServices.dylib 0x2dca2c29 cache_thread_entry(void*) + 441
8 AssimCore.dylib 0x00034a48 as_thread_entry(void*) + 26
9 libSystem.B.dylib 0x927436f5 _pthread_start + 321
10 libSystem.B.dylib 0x927435b2 thread_start + 34
Thread 9:
3 REDCODE.node 0x4a4438c2 kdu_thread_entity::process_jobs(kdu_thread_queue*, bool, bool) + 468
4 REDCODE.node 0x4a445529 worker_startproc(void*) + 53
5 libSystem.B.dylib 0x927436f5 _pthread_start + 321
6 libSystem.B.dylib 0x927435b2 thread_start + 34
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
0 dyld 0x8fe12793 SegmentMachO::getActualLoadAddress(ImageLoader const*) + 19
1 dyld 0x8fe0e46f ImageLoader::containsAddress(void const*) const + 63
2 dyld 0x8fe06f22 dyld::bindLazySymbol(mach_header const*, unsigned long*) + 226
3 dyld 0x8fe18b6f stub_binding_helper_interface2 + 21
4 AssimCore.dylib 0x00025a4e as_modulename(char*, int) + 0
5 libSystem.B.dylib 0x9277f09b _sigtramp + 43
6 ??? 0xffffffff 0 + 4294967295
7 REDCODE.node 0x4a39199e kd_decoder::do_job(kdu_thread_entity*, int) + 8062
8 REDCODE.node 0x4a443c1e kdu_thread_entity::process_jobs(kdu_thread_queue*, bool, bool) + 1328
9 REDCODE.node 0x4a445529 worker_startproc(void*) + 53
Thread 19:
Thread 20 Crashed:
0 libSystem.B.dylib 0x927f3dbe __semwait_signal_nocancel + 10
1 libSystem.B.dylib 0x927e5c87 usleep$NOCANCEL$UNIX2003 + 61
2 libSystem.B.dylib 0x9280748b abort + 85
3 REDCODE.node 0x4a476abb 0x4a371000 + 1071803
4 REDCODE.node 0x4a3dc49d kd_tile::read_tile_part_header() + 2213
5 REDCODE.node 0x4a3ddc59 kdu_subband::open_block(kdu_coords, int*, kdu_thread_env*) + 889
6 REDCODE.node 0x4a38fb9e kd_decoder::do_job(kdu_thread_entity*, int) + 382
7 REDCODE.node 0x4a443c1e kdu_thread_entity::process_jobs(kdu_thread_queue*, bool, bool) + 1328
8 REDCODE.node 0x4a445529 worker_startproc(void*) + 53
Thread 21:
Thread 22:
0 libSystem.B.dylib 0x927438c1 __pthread_set_self + 13
Thread 20 crashed with X86 Thread State (32-bit):
eax: 0x0000003c ebx: 0x927f390f ecx: 0xb0a4b8bc edx: 0x927f3dbe
edi: 0x00000000 esi: 0xb0a4b918 ebp: 0xb0a4b8f8 esp: 0xb0a4b8bc
ss: 0x0000001f efl: 0x00000247 eip: 0x927f3dbe cs: 0x00000007
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x4d468000
Did you try deleting your Redcine preferences? I know you said you re-installed the program but that doesn't necessarily mean you deleted preferences in your Library.
I tried that but it didn't work. Weird thing is... just before REDCINE crashed I noticed that a couple of the shots sitting in the line-up at the bottom of the screen were black with a red (E) in the upper left-hand corner. I've never seen that before. Has anyone else seen that before?
can you load those shots manually in REDALERT and see what that says? or see if it crashes REDRUSHES as well?
I trashed the prefs but it didn't help. Sorry, should've been more specific.
Apparently I can open them in both REDRUSHES and RED ALERT. I guess that rules out there being a problem with the files themselves.
I haven't tried uninstalling and reinstalling Final Cut Pro yet. I sent detailed messages to Ian Bloom and the guru's at RED. Hopefully they have a solution I can use before going as far as reinstalling FCP.
