- Moderator
- #21
Jeff Kilgroe
Interesting concept there, ibloom.
I agree with you on the "shutter artifacts" exhibited by RED, but I'm not so sure a mechanical solution like this or even a conventional mirror shutter will do a whole lot to eliminate the effect, let alone eliminate it. I suppose it's worth testing.
I'm also interested to see if we get different motion and shutter characteristics with the new batch of cameras vs. the current 100.
I'm interested in negating these artifacts as well. Especially the split-frame effect of uncontrolled strobes, pyro effects or muzzle flashes. Some of this can be duplicated on film cameras as well, but the effect is softened -- actually no where near as sharply defined as on the RED. That's probably what you're aiming for. Other digital cameras that do not exhibit these effects are CCD sensor cameras that do not have a scanline "rolling" shutter, but rather a simultaneous read of the entire sensor array.
