Kind attn: Michael - Audio non-sync in 24p PAL Project?
gbalaji
Chennai, Tamil Nadu, India
www.indieshd.com
Michael
I try export ALE from Red Rushes.
Created 24p PAL project
In format changed to 1080p24
Imported the ALE
Selected all clips and modified and added audio track 1
Changed the format settings to 24p PAL
Batch imported the files
When I try to play the file the audio is non-sync and early than video?
Please suggest the reason for non-sync and I have already imported 2500 clips worth of material running for 10 hours.
What 24p PAL project did you make, Method 1 or 2? I would also import all the audio into the 1080p project to start -
Michael
I'm using method 1. Is the method 3 you mentioned in earlier post ready yet?
Method 3 is a concept only. Not any engineering roadmap at this time. With HD post becoming easier and cheaper, the priority to enhance SD workflows for high rez production goes down. It is something we are tracking, but not it is not the top of the list.
Import your audio in the 1080p/24 project first.
Michael
Thanks Michael.
I now move to 1080p24 project in DnXHD 36 codec. Will follow for my next project for using SD under method 2.
