A "real" 4k from a 5k - 6k camera
Joe G.
politicalfilm.wordpress.com
Much has been said about how the 4k from a Red One is "effectively" a 3.2K or some even say 2.5K "effective" resolution. Is there a white paper that puts this into a coherent explanation?
So, at what point do these new cameras become an "effective" or a "real" 4K image?
What determines the actual resolution?
How can these 5 or 6K images be turned into real 4K quality images suitable for the big screen and a high end 4k post production workflow?
When will we learn more about this workflow, which at the moment seems non-existent?
The Red One is already suitable for the big screen. At least what I've seen on the big screen at Warner Bros. Both on film and digital.
The highest measured "real resolution" of 35mm film is 3.2K. And that is slow film. ISO 500 film is under 3K. Just for your reference...
Jim
Effective resolution is measured by the resolution that can be "resolved" from details on screen, like a camera test chart with small details.
Your post seems to be putting 4k at the gold standard of what you think is suitable for the big screen. Remember that Star Wars was shot at 1080, and Lord of the Rings was scanned, DI'd and printed back at 2k.
When you say that you want a workflow for a "real" 4k image, you're saying that you want a workflow for 5k or 6k, right? The answer is... probably when a) cameras are released to the public that image at 5, 6, etc., and b) when you make it happen. If you want workflow that is set in stone and everyone knows how it's supported through and through, go shoot some film. If you're going to pick up a device that is brand new, is rewriting several rules, less than a year after the first models are released, you're going to have to accept some of the growing pains.
And, practically, the workflow looks like...
Edit with proxy files, conform and color with a 5, 6, 9k master, then render out 4k images.
Effective resolution is the measured resolution. That means pointing your camera at a test chart, and reading off the result. However, in reality it's more complex than that.
Many "HD" camera systems are so desperate to appear sharp and detailed that they do not adequately filter out the detail that lies above which the camera can record. At RED, we're a bit conservative with our filtering. We want to ensure that you don't get any false details, or aliases appearing in your images. There are a number of reasons why this is important, not least how these false details can increase the perception of motion judder, make it harder to compress for broadcast or distribution via a motion adaptive codec, or just plain look ugly.
Instead, with RED, you get a more natural level of detail, not forced, that looks to me more how the eye sees things.
Graeme
Correct answer Tico!
Graeme
Trouble is that it is hard to quantify sharpness in relation to aliasing, because how much aliasing you want to accept in order to gain the impression of more sharpness is a judgement call on the part of the camera designer.
Simply telling you the number of lines resolved, or the MTF of the system, etc. doesn't give you the whole picture, so to speak, in regards to sharpness, detail, resolution, and the perception of those things (and perception is a valid thing to consider). Which is why opinions can vary so much, and why you should shoot your own tests and make your own judgments.
The real problem with this whole 4K resolution benchmark, while a theoretical ideal, is that there really isn't a real world example to compare against. You'd almost want to design a test image shot with a 4K monochrome sensor in three passes filtered red, green, blue as some sort of digital 4K RGB standard to measure all movie cameras against. But even then, you'd have to decide how much aliasing to accept in the system.
I'm not sure there really is a simple engineering figure or measurement that can sum up the whole picture regarding resolution.
I'm not sure studying single frames either is a completely accurate picture since detail on film lies on different grains on each frame, and our eye averages information of a couple of frames during projection. Some people use the term "temporal resolution" to describe some of the effects of shooting and projecting at higher frame rates, though I'm not sure if that's a real engineering concept.
I think many of us can agree that what we want is an image containing a lot of fine details without aliasing artifacts and without the impression of artificial sharpening tricks. One way to get that is by oversampling, hence why 70mm and IMAX photography looks so nice -- lot of fine detail, low grain, but not edgy-looking. So larger sensors with more photosites will help in this regards.
David, with answers like that you're putting me out of a job!
Graeme
I think it would serve us all very well if Red commissioned an education orientated micro site full of tests and white papers... The above needs to be screamed loud somewhere you can point people to...
I've pointed loads of people to the Panavision/canon lectures despite the anti-red bias just to get people to understand that they don't have the understanding framework they think they have (the megapixel + latitude reductive thinking challenge)
I've been curious about this for a while and would love to know more...
The augmentation of resolution through time and tiny spatial differences in detail is analogous to 3d resolution augmentation. 3d rez augmentation feels about 30-50% ... (obviously this only happens with certain active display technologies)
regards
Michael L
I wish we had time Michael, but we're way too busy making cutting edge cameras and innovative image processing and codecs. The best we manage is a quick post on this forum to help explain the issues.
Graeme
Graeme
Hey I'm a amazed you manage what you do...I've personally learned quite a few things... maybe two literate technology interns for 1 year (with full Red resources) and you oversee their work?
just an idea..
I think its important because you (personally) make the same points over and over again every few months to a different load of REDUSERS.... And David (near to being made a saint) Mullen would probably benefit too :shifty:
thanks again
Michael Lindsay
Jim
Are you talking about the "native" 35mm negative resolution or the resulting resolution of a 35mm print passing the negative / interpositive / internegative / positive distribution process?
35mm neg /positive direct print process is beautifull.
Patrick
I believe he's talking about what can be measured on a 35mm negative.
What gets confusing is that there is a difference from measurable resolution of a negative versus optimal scanning resolution of a negative, which tends to be higher than measurable resolution. There are some benefits, again, with oversampling the negative in a scan, which is turn may be oversampling if you end up in 2K or HD for a final master.
While I haven't shot my own tests, I can believe that 35mm color neg falls in the 3K to 4K range in terms of measurable line resolution, just from my experience doing 2K and 4K D.I.'s.
Of course, color neg doesn't have any aliasing artifacts (plus it has a wider dynamic range.)
Also, 3K or 4K describes horizontal pixel resolution -- some film formats like 4-perf 35mm anamorphic benefit from greater vertical resolution than 35mm formats that involve cropping to achieve 2.40, if that's your intended aspect ratio.
We're obviously getting into that zone where many modern digital cine cameras are in the ballpark of matching 35mm resolution, but that also means that now we're getting into the nitty-gritty details of the particular "feel" of how these cameras handle fine detail versus how film does, which is why I feel that we don't have adequate simple engineeering numbers to describe that difference.
I recall a discussion I had with Dale Launer about audio engineering, he being a real buff on the topic, and he mentioned that when digital sound came out, every engineer pointed out how it was measurably better than analog sound, yet musicians kept saying that certain aspects were not as good to their ears. The engineers would sort of dismiss those comments until later it turned out that they simply weren't measuring the sorts of things that the musicians' ears were hearing. So the problem is that we may not have adequate tools to quantify what we are seeing with our own eyes, at least, not in a way that gives us a simplistic numerical value. Hence we fall back into inaccurate or inadequate terms like "4K" to describe sharpness.
Patrick
It IS beautiful, but oddly enough, emulsion to emulsion contact printing actually is less sharp than step optical printing of the neg to print. But some people prefer the look of contact printing anyway since optical printing (assuming the same number of generations involved) tends to oversharpen the grains.
Film should suffer from aliasing, but due to the random sampling used by the film grains, it's not particularly visible. You've essentially traded random noise from the grains for lack of aliasing.
When you scan film, that's a fixed sampling process, and you do need to be very careful about aliasing, especially if you scan at a high resolution then downsample. I've seem some pretty stupendously bad aliasing artifacts from film sourced material that has been downsampled from a high rez scan, and they're not pretty.
David, you're right that the "feel" of an image is often hard to quantify. I think we said earlier on that at RED we prefer the rich taste of a nice dark chocolate in our images as an attempt to describe the image feel we were going after. Words work better than numbers for this.
However, in the new year, I get the feeling that the rich bold delicious melt-in-the-mouth taste of RED is going to get a whole lot tastier, but still keep the same great taste we know, enjoy and love!
Graeme
The ONLY reason to "go digital" over film is that film is problematic. While we ALL agree that it is BEAUTIFUL beyond measure, it is expensive, not very earth-friendly, takes up space (ever seen what a feature's worth of film looks like?), it cannot be quality-checked without processing, etc. For the "switch to flip" to all digital, we need to equal or beat film in every aspect. The 1st digital programs did not do it. But they got the ball rolling. Now we are close in many ways... and it is now easy to see that digital will surpass film in every way in the future.
The question is no longer if... it is when. The RED ONE went a long way to bridging the gap between "early digital" and a film replacement. We call it an acceptable "film alternative". The film replacements are on the way. Whether it is RED or someone else... it is coming. As DNR continues to improve and workflows follow, it will be hard to make a case to shoot film in the future. I did not say now.
A few facts... there are NO new film cameras in development that we know of. The film camera companies are looking for digital solutions, even though they know it puts pressure on their legacy.
It seems to me that the struggle between film and digital is counter-productive. The push, IMHO, should be to get the digital camera companies to make better digital equipment so there is no longer any compromise as a film alternative.
Jim
Jim
When I saw Che I knew it already happened. Thank you Jim.
Jim
Best reason by far,
and the less plastic you use (in construction of the camera) the better.
Glad to hear RED is a little green.
EDIT: Merry Christmas everyone!
