For Sale - Set of LOMO square front anamorphic F=35mm,50mm,80mm T2 - PL mount ,
St.Petersburg , Russia
Up for sale set of square front anamorphic lenses F = 35mm/2 , F = 50mm/2 , F = 80mm/2 . Lenses remount on PL and has focus gear ring with ARRI standard 32 pitch .Lens clean and clear , has no fungus or dirty inside , multicoating fine .Lenses has front and rear caps . .If you have any question please write me .Asking $ 4200 for one set F = 35,50,80
I have now 2 set of LOMO square front :
Serial # :
Lens F = 35 mm / 2
1 – 35BAS10 – 2 # 680002
Close focus - 1m
Relative aperture - 2.8 - 16
Weight - 1.3 Kg
2 – 35BAS10 – 2 # 830004
Close focus - 1 m
Relative aperture - 2.4 - 16
Weight - 1.3 Kg
Lens F = 50 mm / 2
1 - 35BAS4 - 6 # 65-10
Close focus - 1.5 m
Relative aperture - 2.5 - 16
Weight - 1.9 Kg
2 - 35BAS4 - 15 #670010
Close focus - 1.6 m
Relative aperture - 2.5 - 11
Weight - 1.6 Kg
Lens F = 80 mm /2
1 - 35BAS4-7 # 7203
Close focus - 1.5 m
Weight - 2.3 Kg
Length - 195 mm
2 - 35BAS4-16-01 # 720029
Close focus - 1.5 m
Weight - 2.3 Kg
Length - 185 mm
One set I can sell separately
Best wishes.
Merry Christmas !
sergastr@list.ru
sergastr@yahoo.com
Sergey
The round front are a newer design, with the anamorphic element in the middle of the optical assembly instead of the front. They breath less, and exhibit less artifacts. they also most likely have better multicoatings, being newer.
The square front were made up until the early '80s. I have a 35mm from '82. Just from looking at it, it seems the coatings are different than the lenses from the mid 70's. The square fronts breath more, and being the older anamorphic element in the front design, exhibit more of the classic anamorphic artifacts such as flairs. The square front 35mm is considered by some to be superior to the round front, having less distortion and being smaller and lighter.
The easiest way to see something shot on the square fronts is probably to go rent Solaris. There are a lot of soviet movies shot in "Sovscope", but thats one of the better known and easiest to get your hands on.
I have yet to buy a lens from anywhere in the former soviet union that did not need cleaning and servicing when I got my hands on it. Duclose has done excellent work, and I know that Bernie at Super16 works on them.
The square fronts go 35,50,80. The round fronts, 35,50,75. After the 75mm they are different versions of the same lens with extenders built in.
I really like the look of most of the newer soviet lens designs, and if you have them cleaned and lubed, they perform very well mechanically.
Nick
  • Thread starter
  • Banned
  • #9
I have now 2 sets of LOMO square front anamorphic
Serial # :
Lens F = 35 mm / 2
Lens F = 50 mm / 2
Lens F = 80 mm /2
1 - 35BAS4-7 # 7203
Best wishes
Sergey
sergastr@list.ru
sergastr@yahoo.com
