Set of 3 LOMO roundfront anamorphic lenses F=50/2, F=75/2 , F=100/2.8 - PL mount
St.Petersburg , Russia
Up for sale set of LOMO roundfront anamorphic lenses 35BAS22 – 1 F = 50 mm , 35BAS23 – 2 F = 75 mm and 35BAS25 – 1 F = 100 mm . This type of lenses has absolutely equal front anamotphic part therefore we made conversion and now this set has one front anamorphic part and different rear parts with prime lenses F = 50 mm F = 75 mm and F = 100 mm .Rear parts can connect to front anamorphic part during seconds by means of bayonet ring .All 3 lenses check up carefully Flange Focal Distance on collimator and test on optical bench .Lenses has PL mount and front part has Focus gear ring with ARRI Standard 32 pitch . So you will have 3 roundfront anamorphic lenses and you will save your money !!
I am asking only $ 5700
For example Ken Rich : http://www.lomo235.com/ ask only for F = 100 mm 35BAS25-1 $ 5250
Best regards
Sergey
sergastr@list.ru
sergastr@yahoo.com
  • Thread starter
  • Banned
  • #2
Hi !
I am have received message from potential buyer :
I thought the lenses are the round anamorphic lenses. Now i read that they are all normal spherical lenses with one anamorphic adapter. Sorry, but i am looking for the real anamorphic lenses, so i am not interested in these. Sorry, should have read the listing first, but i was just too exited to see some round anamorphics listed.
Now I am else one time try to explain - Front anamorphic part - it NOT ANAMORPHIC ADAPTER !! , it is part from standard LOMO lenses 35BAS22 - 1 ,or 35BAS23 - 2 , or 35BAS25-1 when you connect rear part to front anamorphic then you will has STANDARD LOMO Roundfront Anamorphic lens 35BAS22-1 F = 50/2 , or 35BAS23-2 F = 75/2 , or 35BAS25-1 F = 100/2.8
Best regards
Sergey
sergastr@list.ru
sergastr@yahoo.com
To help Sergey clairify -
The round front anamorphics had the same lens for the longer focal lengths with extenders attatched.
For example, the 75mm and the 100mm round fronts are the same lens with a built in extender on the 100mm.
What Sergey has, is a 50mm, with a set of quick change extenders to make it the longer focal lengths. These are real round front anamorphics.
Hope that helps,
Nick
