Hi guys,
I recently tried to convert some R3D files to Avid DNxHD Quicktimes.
For some reason the QT files had a maximum duration of 00:01:33:15fr
But when I looked at the R3D proxies the duration was longer. Which meant RED Rushes had cut off the end of alot of the R3D files.
Has anyone else came up against this before? Having RED Rushes only convert a maximum duration of 1min 33secs and 15fr worth of footage when it should be longer??
(Also, when the clips were imported into RED Rushes it gives the correct duration of the R3D files, which I then create an ALE from but once Batch Imported into the Avid, with the shorter-lengthed QTs Avid DNxHD, it seems as though the Source Timecode is incorrect and the EDL references the wrong shots when we attempted to conform through Monkey Extract to the Flame)
