I would really appreciate a bit of guidance as I try and iron out the final details in my plan... I plan on transferring the R3D files to Prores for cutting, going Crimson to Redcine, doing a one-light, and exporting DPX files using RedLog gamma & CameraRGB (or would Redspace be better?) color space. From there I will get a LUT from the film-out house and do the color grading in Color. I'll finish with DPX files on a RAID that I can take to the film-out house and have transfered. Now, to create an HDCAM SR master that can be screened at festivals as well as HDCAM, Digibeta, and DVDs can I grade my original DPX files (prior to exporting from Color for film-out) or do I have to start back at Redcine and export using Rec709 gamma and Redspace color space in order to have the master be YUV? Is there any reason I would need both a RGB and YUV HDCAM SR master? What is the best way to create both a version of the film for a film-out and an HDCAM SR master and the various deliverables I'll need? Finally, going back to the source, what color space and gamma settings should I use on the camera while shooting? Thank you so much for your advice. Tommy
