Häakon
I've been wanting to say something about this for awhile, but haven't had the brainpower to articulate it until tonight. Maybe someone else has some thoughts on this as well.Most people who own a FF35 will be using PL-mount glass on it in a windowed super 35mm mode.
I remember when I bought my first full-frame dSLR (a 5D) and was comparing the images to my previous dSLR (a 1.6x crop XTi), and the ever pervasive discussion about "zoom factor" came up when comparing the two. That is, with the same glass on both cameras, a 50mm lens on the 5D "becomes" an 80mm lens on the XTi, because you're covering a smaller sensor area and you're really only using part of the glass on the cheaper camera. So while some people have declared that you actually get "longer zoom length" on a cropped camera, we all know that isn't to be true - you're really just seeing part of the picture. I demonstrated that one could just as easily take a center crop of the 5D image to match the size of the XTi's frame, and you'd end up with the same FOV. Again, most of us understand this concept, especially after having shot with the RED ONE's "windowed" modes. Here's where the kicker comes in, though.
The 5D's sensor is 12.8MP while the XTi is 10MP. So while the XTi is a 1.6 "crop" camera, it doesn't have 1.6x less total resolution. Thus, the 5D's photosites are larger (a good thing), but when you take that center slice out of the 5D image to match the frame size of the XTi (and get an equivalent FOV), you actually end up with an image that has less resolution than the "inferior" camera. And when looking at comparative images, it's actually quite a noticeable difference. Now normally this isn't an issue, because you do have lenses that cover the entire full frame and thus you don't waste anything - you get the benefits of both added resolution as well as the larger pixels (better noise performance, more DR, etc.).
However, if you're planning on just using good ol' PL-mount lenses on the FF Epic (specifically ones that only cover the S35 frame), you are making that sacrifice and throwing away quite a good bit of the sensor. And since the jump in resolution between the two cameras isn't very much (5K vs. 6K), one would have to assume that the pixels are indeed quite a bit larger on the FF Epic (I believe they posted specific pixel size information during the November announcement but removed it from the updated Dec. 3 rollout). As a result, you're going to take a decent hit in resolution when shooting this way. To put it another way, you'll likely have more pixels (and in turn higher detail rendition) when shooting with a PL lens on the S35 Epic than the FF35 model.
Of course the monkey wrench in the equation is that the sensors are not the same, and the "Monstro" sensor is supposedly one generation better in terms of latitude and noise and all of that fun stuff. So it doesn't make the comparison apples to apples, because we're dealing with more than just a loss of resolution here.
I do put this out, however, because it seems like with no response to all of the requests for a S35 Monstro camera from RED (it really does appear that this is the best solution more and more every day), many users are thinking of jumping up to the FF version, putting a PL mount on it, and calling it a day. Admittedly, there are still many unknown variables here - not the least of which is the fact that we have no samples of image quality from either of these cameras - but it's just food for thought for those who may be considering this route. That 5K S35 Epic X may just be the best choice yet.
