- Banned
- #1
Matthew Rogers
Banned
- Mar 9, 2007
- Age
- 44
- www.macvilleproductions.com
Hey guys, I was going to post this in the Rowland proxy workflow thread, but I didn't want to have it buried.
After doing some testing this morning I figured out why you get sometimes get clips from the proxy workflow rendered out of Color that jump/repeat. If you have a R3D file that spans multiple R3D files and your edit goes over that break, then it seems Color freaks out and can't connect to the next the next R3D file! Say your "take" is three R3D files (001.R3D, 002.R3D, 003.R3D), if you make your edit so it doesn't cross any of the two breaks, it will render out fine--even if the take is more than one R3D file long.
I am guessing that this is the very reason RED didn't promote this workflow for the native FCP workflow. Color can't connect the R3D's through the proxies, but how RED has wrapped R3D files into a "native" mov format, it can.
So if all your takes are under 2GB, then this workflow is great (or if you can edit around the file break.) Otherwise, I would suggest editing with the offline ProRes workflow or the native file workflow.
It would be great if this could be made a sticky so people don't get confused about the proxy workflow.
Matthew
Matthew
