Steve Harryman
- Nov 1, 2007
Is it possible to have the option of a Nikon mount on a 2/3" Scarlet---I'm assuming that the smaller sensor will create a greater Field of View and magnification ratio with the use of a 35mm telephoto----which is exactly what I want to get greater reach for wildlife. Or is the S35 the only option for having the Nikon Mount (based on the spec sheet from the Nov. 13 announcement)--which I will then need to use in windowed-mode to achieve a greater mag. ratio?
