Simon Baechler
I built this transfer station because I was looking for a clean and fast solution to the problem of moving data around. The goal was to have everything in one box. It should be faster and more powerfull than a laptop but still portable.
So here it is:
It's about the same size as a 17" Mac book but deeper. It has a Core 2 Quad extreme processor with 3Ghz and 4GB of Ram. This means you can convert the footage to Pro Res or DNxHD on the set.
The standard configuration has two integrated CF slots that are SATA based. So a full 8GB cards is downloaded in under two minutes. There is also a LEMO RED drive port. Of course all is hot-swappable.
The data can then be copied to either the internal 1.5TB RAID-5 or a single 3.5" HD that can be replaced when full.
The second target drive is a 2.5" drive module that can go to the editing room every night.
Now I just need to convince the producers to use this instead of a laptop ;-)
So here it is:
