Joshua Provost
Spend almost 5x the amount when it should only cost at most 2x as much for 3k in a larger sized sensor?
Hm, the S35 sensor has about 4x - 5x more surface area, not 2x. I'd say the price difference is about right on.
Everyone here thinks that the 2/3 sensor is going to be like a baby Red1. It can't be. It will be noisier. It will have worse low light performance. It will require better glass. The photosites are 40% smaller. Unless they've developed a totally different kind of sensor (They haven't said this) it will be a totally different and inferior camera.
The 2/3 sensor is a next generation Mysterium X sensor. Higher dynamic range and low light capability than the original Mysterium sensor.
If it was a radical improvement in technology don't you think they would have mentioned it?
One stop better is not a radical improvement. And they don't tell you how much of that is due to sensor design, or improved A to D design, or simply greater bit depth. I'm willing to bet that the improvements will not scale to the smaller size sensor and even then it might not be enough.They have - it will have a full stop better dynamic range than old Mysterium.
One stop better is not a radical improvement. .
Hi,
100% improvement sounds good to me.
Stephen
You are clearly not understanding. Where is the improvement occurring? You could change the sampling or encoding structure and make it 20 bits and claim x stops better. It doesn't mean the raw sensor itself will provide usable information beyond spurious noise. Red has mentioned nothing about ground breaking technology that improves the S/N at the cell level. Do you honestly believe that a a sensor with 5.4 microns will have the same latitude as a sensor with 3.2 microns? IT IS IMPOSSIBLE yet they are spec'd the same. There is healthy fudging on the 2/3" numbers.
And it still doesn't address the fact that you will need expensive glass to go with the lower cost sensor because of the smaller pixel size.
It doesn't matter if Red mini primes are great and they actually design a set just for the 2/3" camera. (The mini primes meant for their other cameras will not be good enough for the 2/3" sensor)We need to wait and see what the RED mini primes will be like before making assumptions like this.
That just means that there would only be a single source for adequate lenses. Does any professional want to be limited to a single option? And it still doesn't address the DOF issue.
The Four Thirds sensor size would give us dozens of options and a better DOF.
RED has indicated that the SENSOR CAPTURES AN EXTRA STOP OF LIGHT -- That's DOUBLE the amount of light (each stop is a doubling of the light; this is an exponential scale).They also estimate an additional TWO STOPS MORE THAN THAT for "monstro" -- that's four times as much light as the X..
Then create a four-thirds mount, stick it on a S35 brain, and crop the results...
Or, stick it on a 2/3" brain, and deal with a crop of the capabilities of the lens.
I would bet that they would sell 90% s35 scarlet 3k for 3k and only 10% of the rest of their other cameras. That would mean alot less money for the company.
I would love to buy the camera you guys are talking about and would buy it in a heart beat. But RED is a business and it wouldnt make sense to sell that camera because it would hurt the sales of all the other cameras they are making. I would bet that they would sell 90% s35 scarlet 3k for 3k and only 10% of the rest of their other cameras. That would mean alot less money for the company.
I will stick with the 2/3 scarlet for now but my vote is definately for the camera your proposing.
Jim you guys have done a great job but when will you release the price for the fixed lense scarlet?
I was suggesting the Four Thirds format @ 3k because it would have the same cell structure size as all of the other models announced (5.4 or 6 microns). So it would be fairly easy to adapt using the same Fabs.I'd like to see 4k resolution in a 4/3format as the gap filler
