I think many agree that the term "DSLR killer" was a mistake, but that doesn't mean RED shouldn't try to make these cameras as viable as possible as high-end (and ultra-expensive) still cameras. To that end, I'll offer some suggestions:
- Make the mount for the "Mount" really, really close to the sensor - close enough that a mirror box and OVF with mount could be mounted there. Such a "Mount" would also include a secondary mirror and phase-detection system. If the electronic-only option allows any shutter speed then fine, if not add a FP shutter to this "Mount". That shutter adds no benefit if the electronic option is operational so don't add it unless it's required to gain full shutter speed control.
- Make the AA and IR filters removable and user-replaceable. Landscape folks are always desperate for resolving power and sharpness, and the AA filter, even a good one with high Q, reduces both significantly. Of course, it's still required where patterns might come in and cause moire, hence one needs to be available. Removing the IR filter is a common after-market mod done to help either IR shooters or astro shooters. Making it an OEM option would be a big plus for a high-end product.
- Offer a true "raw" mode - losslessly compressed sensor data. While Redcode is probably highly desirable for motion because of the high data rates, still shooters want lossless, not lossy raw data. If the frame rate drops in this mode, then that's fine. I'd suggest full DNG support to prevent software makers from having to manually add support for your cameras to a new version. With DNG, any converter that fully supports it will automatically get support, even in previous versions.
- The lower the base ISO of the sensor, the better (well, as long as you don't get it by killing quantum efficiency or some ridiculous thing like that). More light captured = less noise and more dynamic range when sufficient light is available.
- Make the basic system - brain/grip/mount/viewfinder - as light weight as possible to be competitive with dSLRs in the "carry it around your neck all day" area.
- If the Canon/Nikon mounts will fully-control those maker's lenses then great, but if only Red's lenses can be fully-controlled, you're going to have to offer some short (20-135mm), fast primes for the full frame 35mm format. The f2.8 zooms are nice, but the 24/1.4, 28/1.4, 35/1.4, 50/1.8, 50/1.4, 50/1.2, 85/1.8, 85/1.4, 85/1.2, 100/2 and 135/2 are well-used and well-loved options for serious users (and who else would buy one of your products?). You'll have to offer at least a subset of them to interest those folks. Three would probably do it - 24/50/100 or 35/85/135.
Just some thoughts.
Just some thoughts.
