Peter Karlsson
- Jan 21, 2007
- Age
- 51
- Stockholm
- www.flowcine.com
I've got a project coming up that involves alot of tricky stuff.
We're going to do a shot where the camera starts 7m in the air pointing right down at the floor and at 3.5-4m it starts to pitch upwards, and at 1.8m it is facing straight horizontally. (think of an airplane diving towards the ground and then at the last moment it straights itself out).
Now, I need to do this shot over and over again (lots of greenscreen passes, that needs to add up), and have exactly the same camera movement. However I don't need the same timing. So moving the camera over a span of time of 5s or 10s doesn't matter, as I re-time everything to fit in the end. Its mostly static elements, so only the path of the camera is important.
Our solution right now is using a Milo. But the only Milo available is at the other end of Sweden the day we need it. So either we need to bring one in from another country, or try something else... And the only thing that comes to my mind is to build a "rollercoaster" type of dolly, were the camera hangs on rails.
Does anyone know of a rail system that lets me do it?? Or have any other suggestions on how to make this happen?
/regards Peter K * CG Sweden
