JanneJansson
..then be first with Epic, have an advantage
..then be first with Epic, have an advantage![]()
Yeah that's all good when you have more money to play with. I see a lot of people that got their balls snipped crying on here about not being capable of upgrading to an Epic. Yeah they sure had balls when they bought into an R1. Only to be delayed by accessories back order and an overly saturated market.
$10k to upgrade to EPIC is an awesome deal considering all the improvements.
I think once EPIC comes out, people won't hesitate to upgrade.
Another thing to consider is that, unless there's options to lower the data rate (which I'm sure there will), Epic run at 225MB/sec, which is over 6 times more than Redcode36. At this rate, a RED Drive with 320GB gives you about 22 minutes of footage, and a 16GB card... 67sec. This is without counting the transcode time, the storage needed, etc..
I'm not saying this is a bad thing, but those are things that needs to be taken into consideration as well.
Some explain to me why the FF35 Epic would be better than the S35 Epic again?
Some explain to me why the FF35 Epic would be better than the S35 Epic again? Would the picture quality of cropping the FF35 sensor to a S35 window be the same, better, or worse, than using an EPIC with a S35 sensor?
There are many reasons. The first that most people will point to is that they use different chips - the s35 uses the "Mysterium-X," while the FF35 uses the Monstro. According to the data tables on the new page, the Monstro chip yields two more stops of dynamic range, much better A/D conversion, and larger photosites than the Mysterium. All significant upgrades.Some explain to me why the FF35 Epic would be better than the S35 Epic again?
Like Mark pointed out, I think the whole point of the "brain" approach is that all you need to do to get a better sensor is buy a new brain. All of the controls, outputs, media connections, etc. are separate and will latch on to any brain you choose. That's precisely why they're calling them brains and not bodies. So if you make a RED s35 system and configure it with the components you want and later decide you want the FF35 sensor, you just swap out the brain. No "upgrade" path is necessary. This is not the case for the RED ONE where the controls, outputs, and media connections are all physical parts of the RED ONE body.If the Red One is upgradeable to a Monstro sensor, then I would think that the Epic S35mm is too.
